Choose Elements on round surface
I want to put on pressure load on a wheel rim. The problem is, that the model only has meshed elements and no surfaces. For the pressure, I have to choose the wheel rim surface, but there are too many elements to do it manually. Is there an option to choose all elements on the round surface? I hope I have made the problem clear.
Many greetings
You can try to organize the elements into a collector and then apply the load on elements present in that collector.
To organize the elements: Tool > Organize; Select the elements to be moved and the collector to which it should be moved.
Thank You
0 -
When you select elements (Shell) or Solid faces, try methode 'by face'
