Hello. I am trying to run hyperstudy from batch mode with hstbatch. There appears to be limited documentation for this, but when I run from command line '..\\hstbatch.exe -studyfile [file.hstudy]', the study does not run correctly. The output says it is executing the approach, then immediately finishes and closes out of hyperstudy.
Is there any additional documentation (other than 'invoke hyperstudy' page in help doc) or examples on how to properly set this up? How can I tell hstbatch which study (e.g. opt1, opt2, doe 1, etc.) to run in the file? Are there additional commands required to actually execute the study?
Thanks.
