Solid face selection panel
Hello all,
Anyone knows how to open the panel shown below using tcl commands?
how did you call that panel by GUI?
0 -
it will open when we click on slave entity ids in the left panel. I am using hm 2017 version.
0 -
Hi Vipin
try
::hwtk::pa::Area::multiCollectorEditor12 OnYellow
0 -
Hi @tinh,
It is opening the panel, but how do i get the output elements from this?
or how do i set the selected elements to a particular group?
0 -
Hi all,
I used this commands:
*createmark elements 1 'ComponentName'
*createmark nodes 1 'by sets' 'SetName'*interfaceaddsolidface 'YourGroupeName' 0 1 1 30
But keep in mind, you will have to create a node set first, if you want to use this commands.
hope this is an answer to your question!
regards,
0815
0 -
Altair Forum User said:
Hi @tinh,
I know that the panel is called by hm_private_eemarkorlistpanel
But i am not sure how it works
Why do you need to call this panel?
I think finally it will invoke some * commands as @0815 shows above
So you can use them directly, hooking to GUI is just effective in some cases
0 -
@tinh @0815 thanks for the replies /emoticons/default_smile.png' srcset='/emoticons/smile@2x.png 2x' title=':)' width='20' />
In my case i need the user to select a particular region using that option.
As of now i found a solution by creating faces and calling *createmarkpanel elems 1 'Please select the elements' 1, then delete faces
which is giving same output.
0 -
Hi everyone..
I have use this command*createmark elements 1 'ComponentName'
Thing is i had edited the 2line of the command to
*createmarkpanel nodes 1 'select nodes'
i'm getting a error called 'The selected nodes did not defines any faces.'
I have selected 3 and more nodes to define a face but its not detecting.can anyone please help me out with this
0 -
You have to select 3 nodes on face of a solid comp. I think so
0 -
@tinh Thanks for reply
I have tried on solid component still it was not getting selected.
is there any other solution ?Regards,
Bharath
0 -
will this command select solid elems?
0 -
Yes this will select the solid elements
