Bind Mouse button on tree widget - hwtk::treectrl
vipin_22401
vipin_22401 Altair Community Member
Hi all,
Is it possible to bind mouse button operations on hwtk treectrl widget?
For example I have created a tree like below, when i click on any item, it should act as a button and execute some command.
  • tinh
    tinh Altair Community Member
    edited April 2018
    Hi Vipin
    did you try setting a callback for option -selectcommand when creating the treectrl ?
    when you select some thing it will invoke -selectcommand
  • vipin_22401
    edited April 2018
    Hi @tinh
    I added -selectcommand as you said.
    Anything I select in the tree it is running that command, but how do I assign different script/command for each of the buttons?
  • tinh
    edited April 2018
    Hi Vipin
    example
    set t [hwtk::treectrl $treewnd -selectcommand 'p_AtSelected %W']
    proc p_AtSelected t {
         set items [$t select]
         #you may select more than 1 item so pls handle it
          foreach item $items {
               set text [$t item text $item 0]
               switch -- $text {
                     button1 {
                      button2 {
  • vipin_22401
    edited April 2018
    Hey tinh,
    Thanks a lot for the help. It is working perfectly!!
    I Added -selectmode single, so multiple selection solved :)/emoticons/default_smile.png' srcset='/emoticons/smile@2x.png 2x' title=':)' width='20' />
  • Altair Forum User
    Altair Forum User
    edited October 2019
    can u share me this macros
