Creating a user defined panel
vreddy
vreddy Altair Community Member
How to create a panel with 10 buttons ??
Reference is attached as a file.
OR
Is there any way such that we can open connectors panel and get selected element type (with out going for new panel creation as mentioned above).
  • tinh
    tinh Altair Community Member
    edited July 2017
    :rolleyes:/emoticons/default_rolleyes.gif' title=':rolleyes:' />
    Do you mean, you want to popup a panel to select something to continue your script?
    example:
    #you're doing something
    #you need to input connector type:
    set SelectedConnector [...] ;# popup a panel to select connector type
    #continue process with selected connector...
    Are you writing a script like above?
  • vreddy
    edited July 2017
    example:
    yes , i want same thing as you mentioned.I want to select a type from connectors->element type panel ->use that type for creation.
  • tinh
    edited July 2017
    There a several ways, you can create your own panel by hm_framework, then push it and wait for its return.
    But I used an available hypermesh panel to do that B)/emoticons/default_cool.png' title='B)' />, you can try using this proc:
     proc hm_callmenupanel args {     set itemlist [lsort -unique $args]     #we will use plots, because they can be deleted without affect to our data     *entityhighlighting 0     *createmark plots 1 all     if {[hm_marklength plots 1]} {*deletemark plots 1}     hm_blockredraw 1     foreach item $itemlist {         *xyplotcreate $item ''         *displaycollectorwithfilter plots off $item 1 1     }     hm_blockredraw 0     set selected [hm_callcollectorpanel plots]     *createmark plots 1 all     if {[hm_marklength plots 1]} {*deletemark plots 1}     *entityhighlighting 1     set selected }
    Using it in your script like this:
    #need to input connector type:
    set SelectedConnector [ hm_callmenupanel 'acm (shellgap+coating)' 'acm (general)' 'penta (mig)' 'other connector types...' ]
  • vreddy
    edited July 2017
    Thanks a lot tinh.It really helped me a lot.
