Progress bar / status bar creation inside HM
I am creating a custom HM tab using hm_framework. In the GUI, I am planning to add a progess bar/status bar which should update during the process. As of now, I am able to create progress bar but unable to update it dynamically.
Is there any way to achive this?
Thanks,
Roshan
In loop where you are changing % of progress bar, you need 'update' command to refresh GUI
example
for {set i 1} {$i<100} {incr i} {
set progress_percent $i; #at this time progress bar displaying not yet moved to i%
update; #after updating GUI, progress bar move to i%
if loop is very long (millions of cycles), 'update' will slow down script very much.
so I only 'update' GUI once per 10000 cycles, help to save time while program is not frozen.
0 -
Thanks tinh !
I was not using the 'update' command. /emoticons/default_biggrin.png' srcset='/emoticons/biggrin@2x.png 2x' title=':D' width='20' />
