Altair RISE
Nominate Yourself Now!
Get mass and volume of each component
User: "Jaggs"
New Altair Community Member
Updated by Jaggs
Hello Friends,
I have lets say 100 components and I need to display each collector's mass, volume individually, can you please help me out.
With the piece of code shown below i am able to get net mass, volume of all the collectors which are displayed but not able to get individual collectors'
*createmark components 1 'displayed'
set i [hm_getmark comps 1]
foreach j $i {
set a [hm_getmass comps 1 'by comp id' $i]
puts $a
Thanks in advance.
1 - 7 of 71
    User: "Altair Forum User"
    Updated by Altair Forum User
    foreach j $i {
    *createmark comps 1 $j
    set a [hm_getmass comps 1]
    puts $a
    It is giving the mass of all components because the mark 1 of components has all the displayed components in it. Each time the loop is run the mark needs to be updated with the id of the component.
    User: "tinh"
    Updated by tinh
    Hello Friends,
    foreach j $i {
    puts $a
    Thanks in advance.
    There is available template for component summary
    You can invoke the template from panel Post>summary>load the template 'components'>summary.  (optistruct, with other solver, name of the template file may differ)
    User: "Rahul_P1"
    Updated by Rahul_P1
    Summary may only give mass and not volume in certain user profiles,
    Perhaps you can convert the model to Abaqus format and use the below script,
    <?xml version="1.0" encoding="UTF-8"?>post-4438-0-07238200-1415870633_thumb.jp
    @Jaggs : last solution is writing yourself a TCL script for that image/emoticons/default_smile.png' alt=':)' srcset='/emoticons/smile@2x.png 2x' width='20' height='20'>
    User: "Jaggs"
    OP
    Updated by Jaggs
    Thank you very much for the help people.
    I have one more question, i need to find the volume of the solid now and I am using this commant 'hm_getvolumeofsolid solids solidID '.
    My question is what is solid id? Is there any difference between solid id and comp id?
    Please let me know.
    User: "tinh"
    Updated by tinh
    Please let me know.
    Yes, there is a difference
    solids belong to solid object
    comps belong to component object
    so solid is different from comp
    to get solid ids you can use *createmarkpanel solids 1; puts [hm_getmark solids 1]
    to get solid ids stored in component compid you can use *createmark solids 1 'by comp id' $compid;puts [hm_getmark solids 1]
    @Jaggs: Have a look at the page 'Data Names' of Hyperworks's help.
