Hello to all, i would like to know how to isolate only failed elements. it is sometimes really difficult to correct an element, which is in the inside of the model. Thanks,
Umehr
After checking, click save failed at the bottom right in F10 panel. Then go to F5 mask panel; elems-retrieve. The failed elems will be highlighted. First mask, after reverse. You will only see failed elems.
Btw it is really useful to use unmask adjacent elemens botton on the display toolbar for refinement
