Get Name of component
sanket_patil
sanket_patil Altair Community Member
What is Tcl command to get component name and split it?
Thanks.
  • vipin_22401
    vipin_22401 Altair Community Member
    edited November 2018
    hm_getcollectorname comps 101
    how do you want to split?
  • sanket_patil
    if component name is '3532923_M-CROSSMEMBER_ENGINE MTG_BDY_SOLIDS', I only want number '3532923'. how to split it?
    Thanks!
  • Yu-Ju Chen_20500
    Yu-Ju Chen_20500 Altair Community Member
    hi, i guess you can try to rename rather than splitting
  • sanket_patil
    Actually i want to get that number from name and set it as that component's id. so renaming is not good option.
    Thanks.
  • sandeepballiwar
    sandeepballiwar New Altair Community Member
    First get the component name.
    If your compname is 123_comp_comp1.
    use split command and get the number.
    after that use *<span style='background-color:transparent;color:#000000;'>rename</span>collector to change the name.
    Hope this helps.
  • sanket_patil
    @sandeepballiwar Thanks for help. I will try this option.
  • sanket_patil
    Is there any option to rename all displayed components at a time?
  • sandeepballiwar
    i don't think there is any api to rename all components at the same time. You need to write a program in in for loop or foreach loop.
  • sanket_patil
    Ok.
    Thanks for the help :)/emoticons/default_smile.png' srcset='/emoticons/smile@2x.png 2x' title=':)' width='20' />
  • Yu-Ju Chen_20500
    i agree with you!
    i think applying a loop is a better solution
  • sanket_patil
    @Yu-Ju Chen @sandeepballiwar I have used for loop and it is working good.
