Error Geometry buiding
Wendpanga
Wendpanga New Altair Community Member
I have a error message when i try to buid the volumes of my geometry and in dont know why. Can you help me to fixe it?
i attached th screanshoot of the error messages.
Thank for your help
Best regards!
Fadel
  • asoualmi
    asoualmi
    edited June 2020
    Can you share your Flu project.
    Best regards.
  • Wendpanga
    edited June 2020
    Ok no problem.
    Thanks for your help.
    Best regards!
    Fadel
  • asoualmi
    asoualmi
    edited July 2020
    Sorry for the late answer. The problem comes from the geometry. When I do build volume, Flux display an error message:
    line 160 face 88 face line intersection :(/emoticons/default_sad.png' srcset='/emoticons/sad@2x.png 2x' title=':(' width='20'> 0.013 , 0.014 , 0.002435 )line 161 face 88 face line intersection :(/emoticons/default_sad.png' srcset='/emoticons/sad@2x.png 2x' title=':(' width='20'> 0.013 , 0.011 , 0.002435 )line 165 face 38 face line intersection :(/emoticons/default_sad.png' srcset='/emoticons/sad@2x.png 2x' title=':(' width='20'> 0.011 , 0.014 , 0.0022 )line 165 face 43 face line intersection :(/emoticons/default_sad.png' srcset='/emoticons/sad@2x.png 2x' title=':(' width='20'> 0.011 , 0.014 , 0.0023 )line 169 face 38 face line intersection :(/emoticons/default_sad.png' srcset='/emoticons/sad@2x.png 2x' title=':(' width='20'> 0.011 , 0.011 , 0.0022 )line 169 face 43 face line intersection :(/emoticons/default_sad.png' srcset='/emoticons/sad@2x.png 2x' title=':(' width='20'> 0.011 , 0.011 , 0.0023 )line 172 face 38 face line intersection :(/emoticons/default_sad.png' srcset='/emoticons/sad@2x.png 2x' title=':(' width='20'> 0.01 , 0.011 , 0.0022 )line 172 face 43 face line intersection :(/emoticons/default_sad.png' srcset='/emoticons/sad@2x.png 2x' title=':(' width='20'> 0.01 , 0.011 , 0.0023 )line 174 face 38 face line intersection :(/emoticons/default_sad.png' srcset='/emoticons/sad@2x.png 2x' title=':(' width='20'> 0.01 , 0.014 , 0.0022 )line 174 face 43 face line intersection :(/emoticons/default_sad.png' srcset='/emoticons/sad@2x.png 2x' title=':(' width='20'> 0.01 , 0.014 , 0.0023 )line 181 face 88 face line intersection :(/emoticons/default_sad.png' srcset='/emoticons/sad@2x.png 2x' title=':(' width='20'> 0.01 , 0.014 , 0.002435 )line 182 face 88 face line intersection :(/emoticons/default_sad.png' srcset='/emoticons/sad@2x.png 2x' title=':(' width='20'> 0.01 , 0.011 , 0.002435 )line 208 face 101 face line intersection :(/emoticons/default_sad.png' srcset='/emoticons/sad@2x.png 2x' title=':(' width='20'> 0.03625 , 0.014 , 0.002585 )line 208 face 104 face line intersection :(/emoticons/default_sad.png' srcset='/emoticons/sad@2x.png 2x' title=':(' width='20'> 0.03625 , 0.014 , 0.002485 )line 208 face 105 face line intersection :(/emoticons/default_sad.png' srcset='/emoticons/sad@2x.png 2x' title=':(' width='20'> 0.03625 , 0.014 , 0.002385 )line 210 face 101 face line intersection :(/emoticons/default_sad.png' srcset='/emoticons/sad@2x.png 2x' title=':(' width='20'> 0.03725 , 0.014 , 0.002585 )line 210 face 104 face line intersection :(/emoticons/default_sad.png' srcset='/emoticons/sad@2x.png 2x' title=':(' width='20'> 0.03725 , 0.014 , 0.002485 )line 210 face 105 face line intersection :(/emoticons/default_sad.png' srcset='/emoticons/sad@2x.png 2x' title=':(' width='20'> 0.03725 , 0.014 , 0.002385 )line 213 face 101 face line intersection :(/emoticons/default_sad.png' srcset='/emoticons/sad@2x.png 2x' title=':(' width='20'> 0.03625 , 0.011 , 0.002585 )line 213 face 104 face line intersection :(/emoticons/default_sad.png' srcset='/emoticons/sad@2x.png 2x' title=':(' width='20'> 0.03625 , 0.011 , 0.002485 )line 213 face 105 face line intersection :(/emoticons/default_sad.png' srcset='/emoticons/sad@2x.png 2x' title=':(' width='20'> 0.03625 , 0.011 , 0.002385 )line 215 face 101 face line intersection :(/emoticons/default_sad.png' srcset='/emoticons/sad@2x.png 2x' title=':(' width='20'> 0.03725 , 0.011 , 0.002585 )line 215 face 104 face line intersection :(/emoticons/default_sad.png' srcset='/emoticons/sad@2x.png 2x' title=':(' width='20'> 0.03725 , 0.011 , 0.002485 )line 215 face 105 face line intersection :(/emoticons/default_sad.png' srcset='/emoticons/sad@2x.png 2x' title=':(' width='20'> 0.03725 , 0.011 , 0.002385
    and when I check the faces (38,43,88,101,104 and 105), I found that there is intersection between faces and  lines.
    You need to correct the geometry to build the volumes.
    The Flux version that I use is Flux 2020
    Best regards.
  • Wendpanga
    edited July 2020
    Thanks for the answer. I delete all the faces that creat the intersecions but it is still not possible to build the geometry. I use Flux 2019 and I don't have another error message besides the one I sent above.
    Best regards,
    Wendpanga Fadel BIKINGA
  • asoualmi
    asoualmi
    edited July 2020
    Did you install the 2020 version
  • asoualmi
    asoualmi
    edited July 2020
    Did you install Flux 2020 version? If it is the case, try to use check geometry?
    Send me your new Flu project.
    Best regards.
