Show elements in a pre-defined set in hw
Hello
Can anyone help me to do a 'isolate only' type of operation by command?
I would like to display results on a set defined in hyperview.
hwi GetSessionHandle sess
sess GetProjectHandle proj
proj GetPageHandle page1 [proj GetActivePage ]
page1 GetWindowHandle win1 [page1 GetActiveWindow]
win1 SetClientType 'Animation'
win1 GetClientHandle po1
po1 GetModelHandle mo1 [po1 GetActiveModel ]
mo1 GetSelectionSetList # i can see the available set list with this command
I cant find the way to select only a particular set (knowing its name or id).
Thanks in advance for the help
Hello again
I never undertood when experts like you dont want to answer questions. Is it that the question is too hard to answer or too dumb?
Or is it such a secret that you don't want to reveal it?
Sometimes a simple answer like 'NO we cant do that' is sufficient and it is confusing to see no reply.Anyways you guys provided help till now so thanks for that. I will surely find myself answer for this soon.
0 -
Calme-toi !!!
0 -
TG toi!
0 -
Hi Roche,
You can try the below commands to Set you need:
set setHandle [$modelHandle GetSelectionSetHandle setH1 'Set $id'] set nameSet [setH1 GetLabel] # Can also be: set setHandle [$modelHandle GetSelectionSetHandle setH2 'User_Set $id'] set nameSet [setH2 GetLabel] # User_Set or Set are called pool can be found through GetPoolList # Refer documentation for more info.
0 -
Altair Forum User said:
Hello again
I don't have an answer but I will not say no we can't do because someone else could have right answer, just he is busy. /emoticons/default_happy.png' srcset='/emoticons/happy@2x.png 2x' title='^_^' width='20' />
0 -
Hi Livil Lyle
Thanks for the code, that helped.
Below code to do a 'isolate only' operation by commands. I tried this today and it works!
