Hi all,
For this case, the option in advanced setting, “Calculate only the scattered part of the field" has been enabled. I try to extract the near field information reflected by the sphere only (excluding scattered by the square conductive plate). Is this setting correct? I’m afraid of this result including the scattered part of the field induced by the square conductive plate. If this setting is not correct, how could I extract the scattered part of the field reflected by the sphere only?
One more question, when I change the radius of the spherical near field from 0.3 m to 0.1 m, the results will be quite different, how to fix the radius to a proper value?
