Run Hyperview on linux from hypermesh command line
Pandurang
Pandurang Altair Community Member
Hi All,
I want to open the hyperview on linux from Hypermesh command line
my code:
set interactivePath [file join [hm_info -appinfo ALTAIR_HOME] altair scripts hv]
exec '$interactivePath' -clientconfig hwpost.dat
is it right?
  • Q.Nguyen-Dai
    Q.Nguyen-Dai Altair Community Member
    edited August 2018
    It does not work?
  • Pandurang
    edited August 2018
    It does not work?
    Then How to make it work..
    PD
  • tinh
    tinh Altair Community Member
    edited August 2018
    It's wrong.
    should be
    [. cget -menu].applications invoke 1
  • Pandurang
    edited August 2018
    It's wrong.
    should be
    want to pass tcl file also...how do i pass it
  • Pandurang
    edited August 2018
    https://forum.altairhyperworks.com/index.php?/topic/16182-run-tcl-script-on-hyperview-start/
    used this reference..
    @tinhIt works well for window...but i want same things to be done on Linux...
  • Q.Nguyen-Dai
    edited August 2018
    Under Linux shell, this command should work as same method as Windows.
  • tinh
    edited August 2018
    Yes i think so.
    What is the error, Pandurang?
  • Pandurang
    edited August 2018
    previous: set interactivePath [file join [hm_info -appinfo ALTAIR_HOME] altair scripts hv]
    This is working
    New set interactivePath [file join [hm_info -appinfo ALTAIR_HOME] scripts hv]
    Only diff of altair:)/emoticons/default_smile.png' srcset='/emoticons/smile@2x.png 2x' title=':)' width='20' />
  • Pandurang
    edited August 2018
    It's wrong.
    should be
    Thanks @tinh for above command.
    I explored many things like invoking different commands available on Main Menu Bar, Adding your customised menu in HM.
  • tinh
    edited August 2018
    it's just a wrapped command, if menu entry #1 is not HyperView, the command will not be your expection
    if you want to find direct command, you have to parse its configs by 'entryconfig 1'
    or 'invoke HyperView' instead of 'invoke 1'
  • Pandurang
    edited August 2018
    Yes you are right
    I forgot to mention about this root command:)/emoticons/default_smile.png' srcset='/emoticons/smile@2x.png 2x' title=':)' width='20' /> ::  [. cget -menu] or .hmMainMenuBar
    With this we can walk through Main Menu bar or can add Customised as highlighted...
    <?xml version="1.0" encoding="UTF-8"?>image.thumb.png.8eda731d299938e420d8565525e6355a.png
