Coaxial cable (modelled with surface triangles)
I would like to model a 20 cm coaxial cable in FEKO. I found that FEKO has an example of modeling a coaxial cable named as 'example_34_aw.pre'. But in the recent versions of FEKO, I couldnt find the example file in Examples guide. Do anyone has the file called as 'example_34_aw.pre'. The title of this example is named as 'Example 34: Coaxial cable (modelled with surface triangles)'.
I found this sort of example in the pdf file, page number 3-140 'http://people.ee.ethz.ch/~fieldcom/pps-antenna/doc/ExampleGuide.pdf'
Hello Sra,
These are the old 'scripting' examples and they were the Example guide examples before FEKO had a CAD interface (CADFEKO). You should not need to access these old PRE files and creating the same model in CADFEKO should be very simple - this specific example is particularly easy to create in CADFEKO. The files are still present in the FEKO installation (feko\examples\Miscellaneous\Kernel_scripting_examples).
0 -
Note that CADFEKO now also support scripting. There are really very limited reasons to still use EDITFEKO - it is really just for advanced users.
0 -
Hello JIF,
Again Thanks for your reply. I modeled the coaxial cable according to my specifications, I sorted this out. /emoticons/default_smile.png' srcset='/emoticons/smile@2x.png 2x' title=':)' width='20' />
