If I have d10, d50 and d90 reported for a particle size distribution and I would like to generate a particle bed containing this particle size distribution, how can I input the particle size distribution in the EDEM bulk material section? Is it in the particle ratio section or factory? I can't seem to find the particle distribution settings.
Thank you for your time and consideration
