How to check if my floorplan is made of different materials?
I have completed creating an indoor floorplan on WallMan by choosing different materials like concrete, glass, wood etc. However, I am not sure if all the required materials are included. All the materials are represented with a grey color. Is there anyway I can know if all the materials I selected is still present? If so how can I validate it? Attaching my .idb file herewith.
in WallMan you can see under Edit => Materials how many objects are assigned per material layer.
Under Settings => Local settings you can activate the options 'Fill objects' and 'Colorize materials' then you will clearly see in the 3D view which materials are used.
0 -
this definitely helped! thanks so much @reinerh /emoticons/default_smile.png' srcset='/emoticons/smile@2x.png 2x' title=':)' width='20' />
