tcl code to import .inp geometry
Altair Forum User
Altair Forum User
edited March 25 in Community Q&A
I have a tcl code that modifies an .inp mesh. I want to incorporate an automatic import line to it, however can't seem to get it to work. What I have at the moment is:
*feinputpreserveincludefiles
*createstringarray 2 'Abaqus ' 'Standard3D '
*feinputwithdata2 '#abaqus\abaqus' 'D:/02_Scripting/HyperMesh/unit_cell_1.inp' 0 0 0 0 0 1 2 1 0
When I run this code, the following error message appears: 'The translator does not exist'.
Would anyone be able to assist me with this?
Thanks a lot!
  • Altair Forum User
    Altair Forum User
    edited August 2012
    Ok, turns out that it was a silly mistake.
    The third line of the code should be:
    *feinputwithdata2 '#abaqus/abaqus' 'D:/02_Scripting/HyperMesh/unit_cell_1.inp' 0 0 0 0 0 1 2 1 0
    (a forward slash is used before abaqus)
    image/emoticons/default_smile.png' alt=':)' srcset='/emoticons/smile@2x.png 2x' width='20' height='20'>
  • Altair Forum User
    Altair Forum User
    edited January 2014
    I'm also trying to import .inp files and save them as a single .hm file.
    My .cmf file is:
       *evaltclscript('C:/Users/Lowell/Documents/SSM_Project/PCA_LOO/HM_IMPORT_04.tcl', 0)
    and my .tcl file is:
       *begin 'version 11.0.0.47  1-7-2014  13:12:22'
       *templatefileset 'C:/Program Files/Altair/11.0/templates/feoutput/abaqus/explicit'
       *menufilterset '*'
       *menufilterdisable
       *createstringarray 2  'HyperMesh ' ' '
       *feinputwithdata2 '#abaqus/abaqus' 'C:/Users/Lowell/Documents/SSM_Project/PCA_LOO/RESULTS_BUILDMODEL/model_04/model_04icp.inp' 0 0 0 0 0 1 2 1 0
       *feinputwithdata2 '#abaqus/abaqus' 'C:/Users/Lowell/Documents/SSM_Project/PCA_LOO/RESULTS_BUILDMODEL_OPT/MODEL_04/model_04icp.inp' 0 0 0 0 0 1 2 1 0
       *setdisplayattributes 2 0
       *view 'rightside'
       *writefile 'C:/Users/Lowell/Documents/SSM_Project/PCA_LOO/MODEL_04_COMPARISON.hm' 1
    This works when I open Hypermesh and go to File>Run>Command File and select the above .cmf file. The problem is that this does not work when I try to run it via DOS using:
       hmbatch -cC:/Users/Lowell/Documents/SSM_Project/PCA_LOO//HM_IMPORT_04.cmf
    I get the following error:
       Tcl/Tk script error:
           while executing
       '*feinputwithdata2 '#abaqus/abaqus' 'C:/Users/Lowell/Documents/SSM_Project/PCA_LOO/RESULTS_BUILDMODEL/model_04/model_04icp.inp' 0 0 0 0 0 1 2 1 0 '
           (file 'C:/Users/Lowell/Documents/SSM_Project/PCA_LOO/HM_IMPORT_04.tcl' line 7)
    I don't think this is a syntax issue because the files work when I manually open HM but I'd like to do this all through DOS.
    Much thanks!
  • Altair Forum User
    Altair Forum User
    edited November 2014
    I am having the same issue as lowell. The tcl script works within the Hypermesh GUI, but fails with the same error using hmbatch. Would appreciate any help being offered!
  • ATLURI BHARATH KUMAR
    ATLURI BHARATH KUMAR Altair Community Member
    edited March 25
    can anyone tell why hmbatch import is not working?
