Import from excel
Hello all,
I have a list of coordinate point of coil spring model in excel.
Is there a possibility to import this point coordinate information to Hypermesh so that nodes as well as lines can be generated ? Using tcl command maybe? or notepad files?
Thank you very much in advance.
you could use the following script http://www.altairhyperworks.com/Macros_Download.aspx?download_type=macro¯o_id=235&from_page=%2fMacros_Exchange.aspx%3f
you may need to modify it.
0 -
Hi there,
it's a very simple tcl code,
like this ex.
your excel file ==> Save as... CSV format:
xCoord,yCoord,zCoord
0,0,0
1,1,0.5
1.4,1.4,1.0
tcl file:
#read the csv file
set csvfile [open csvfilename.csv r]
set NodeList {}
while {![eof $csvfile]} {
gets $csvfile line
set NodeCoords [split $line ,]
#create the nodes
if {![catch {eval *createnode $NodeCoords 0}]} {lappend NodeList [hm_entitymaxid nodes]}
close $csvfile
#create sprial
eval *createlist nodes 1 $NodeList
*linecreatefromnodes 1 2 150 5 179
I usually write tcl codes like those
If you need my help, don't hersitate
/emoticons/default_biggrin.png' alt=':D' srcset='/emoticons/biggrin@2x.png 2x' width='20' height='20'>
rgds,
0 -
@Tinh: Hello, I have almost similar issue.
I have an excel file (.csv format).I need to retrieve the data in my first column as a list.
I placed my csv file in my TCL script folder and tried your above TCL script i.e.
'set csvfile [open MaterialData Al6063 - Copy.csv r]'
'Tcl script error (Tcl/Tk Script) : wrong # args: should be 'open
fileName ?access? ?permissions?'
while executing
'open MaterialData Al6063 - Copy.csv r'
invoked from within
(file 'D:/RWTH/Mini thesis/V6/TCL V4/Untitled3.tcl' line 6)
invoked from within
'source {D:/RWTH/Mini thesis/V6/TCL V4/Untitled3.tcl}'
('uplevel' body line 1)
invoked from within
'# Compiled -- no source code available
error 'called a copy of a compiled script''
(procedure '::hw::RunTclTkScpt' line 1)
invoked from within
'::hw::RunTclTkScpt 219' 'I would be really glad,if you can look at the above issue and reply.
0 -
it should be :
set csvfile [open 'MaterialData Al6063 - Copy.csv' r]
because your file name has space
