Anyone have any suggestions on how to create pressure loads at element centroids by applying an equation? Thanks so much!
I found a great Hyperworks Tip/Trick (#396) for creating a variable loading, but the 'Field Loads' Macro mentioned in the document is not available on the macro menu. Which macro file should I be loading to be able to find this menu? I also tried the instructions found in the Hypermesh 8[1].0 User's Guide.pdf, on page 337, after loading the dlm.mac. The 'Math...' is no where to be found and neither is the Field Loads macro on the Geom/Mesh menu.
