About *createmark
Altair Forum User
Altair Forum User
Dear All,
I have a question about *createmark. I think this question may be fundamental but since I am new to tcl/tk scripting language, I really need some help with this.
Assume I have chosen a set of nodes by using tcl command as follows:
*createmark nodes 1 'on plane' 0.5 0 0 1 0 0 .0001 1 1
# choose all nodes in that plane
For example in hypermesh it came out with *createmark nodes 1 1-40 121 134
Is there a way that I can select the first and second nodes (1 and 2) inside this mark that I just created and store them into a new mark? I know we can select by choosing them by hand but what I need is a macro that can handle multiple different models so I need to select them using this order.
  • tinh
    tinh Altair Community Member
    edited February 2013
    you can use: eval *createmark nodes 2 [lrange [hm_getmark nodes 1] 0 1]
    to store 1st and 2nd nodes in mark 2
  • Altair Forum User
    Altair Forum User
    I found another better way to do this by select them by their coordinates in order to choose the right ones. Thanks a lot, Tinh
    Chong
  • Enrico_20294
    Enrico_20294 Altair Community Member
    edited April 2019
    Hi All,
    I have to select a surface, but I can't use the surface ID. is there a way to select a surface that is X mm far from a specific point?
    Where can I found a manual or a reference guide for the tcl language?
    Thanks,
    Enrico
  • Pandurang
    Pandurang Altair Community Member
    edited April 2019
    Hi All,
    Thanks,
    Enrico
    Consider the plane X mm from your point and mark the surfaces on that plane.
  • Enrico_20294
    edited April 2019
    how can I do that?
  • tinh
    edited April 2019
    Hi
    Use hm_measureshortestdistance2
    Easier than *createmark
  • Enrico_20294
    edited April 2019
    Hi Tinh,
    where could I find a reference guide to learn how to use the commands?
    Thanks,
    Enrico
  • Pandurang
    edited April 2019
    Open Hm--> Press F1 key--> under Help Tag You can find 'Reference guide'
  • Altair Forum User
    Altair Forum User
    edited August 2020
    Hi Forum,
    I am trying to select elements based on their element normal.
    I have a user selected element and I want to select the elements with same normal as the one which user has selected.
    Is there any option to do that in HM??
    Thanks
    Akash
  • Q.Nguyen-Dai
    Q.Nguyen-Dai Altair Community Member
    edited August 2020
    If there is no existing function, you can do it 'manually' :D/emoticons/default_biggrin.png' srcset='/emoticons/biggrin@2x.png 2x' title=':D' width='20' />
    Just a point to know: it better to give some tolerance by selecting elements by normal.
  • Q.Nguyen-Dai
    edited August 2020
    Here's my script (tested only with SHELL elements) to select elements based on normal of one element. The tolerance will be applied at angle comparing.
     # Tested only with SHELL elements # Reference element *createmarkpanel  elems 1 'Select Elem' set elist [hm_getmark elems 1] hm_markclear elems 1 set eid_ref [lindex $elist 0] set nx0 [hm_getvalue elems id=$eid_ref dataname=normalx] set ny0 [hm_getvalue elems id=$eid_ref dataname=normaly] set nz0 [hm_getvalue elems id=$eid_ref dataname=normalz] set v0 [list $nx0 $ny0 $nz0]  # Tolerance for normal comparing, in deg set tolerance 17.0;  # Select all displayed elements hm_createmark elems 1 'advanced' 'displayed' set elist [hm_getmark elems 1] hm_markclear elems 1  #------------------------------------------------------------------------ set selectedElems [list] foreach eid $elist { 	set nx [hm_getvalue elems id=$eid dataname=normalx] 	set ny [hm_getvalue elems id=$eid dataname=normaly] 	set nz [hm_getvalue elems id=$eid dataname=normalz] 	set v1 [list $nx $ny $nz] 	set angle [::hwat::math::AngleBetweenVectors  $v1 $v0] 	if { $angle <= $tolerance } { 		lappend selectedElems $eid 	} }  eval *createmark elems 2 '$selectedElems'; set elist [hm_getmark elems 2] puts 'Selected E: $elist'
  • tinh
    edited August 2020
    If 'foreach' loops through element list taking long time, we can make a template code like this
     # 1. Get sample element: *createmarkpanel elems 1 'Pick an element:' set eid [lindex [hm_getmark elems 1] 0] if {[llength $eid]} { 	# 2. Get sample normal: 	set nx [hm_getvalue elems id=$eid dataname=normalx] 	set ny [hm_getvalue elems id=$eid dataname=normaly] 	set nz [hm_getvalue elems id=$eid dataname=normalz] 	# 3. Prepare a template code: 	set tplCode { 		*elements(103,,,) 		*format() 			*uservariableset(#nx,normalx) 			*uservariableset(#ny,normaly) 			*uservariableset(#nz,normalz) 			*uservariableset(#angle,[57.295779513082195*@acos(#nx*$nx + #ny*$ny + #nz*$nz)]) 			*if([#angle <= $tolerance]) 				*markfailed() 			*endif() 		*output() 		*elements(104,,,) 		*format() 			*uservariableset(#nx,normalx) 			*uservariableset(#ny,normaly) 			*uservariableset(#nz,normalz) 			*uservariableset(#angle,[57.295779513082195*@acos(#nx*$nx + #ny*$ny + #nz*$nz)]) 			*if([#angle <= $tolerance]) 				*markfailed() 			*endif() 		*output() 	} 	# 4. Run the template code: 	set tolerance 5; #degrees 	set tplCode [string map [list \$nx $nx \$ny $ny \$nz $nz \$tolerance $tolerance] $tplCode] 	set fpt [open mark_elems_by_normal.tpl w] 	puts $fpt $tplCode 	close $fpt         hm_answernext yes 	*usercheck mark_elems_by_normal.tpl mark_elems_by_normal.out 0 ;# only displayed elems 	#*usercheck mark_elems_by_normal.tpl mark_elems_by_normal.out 1 ;# include non-displayed elems 	hm_highlightmark elems 2 h 	set elist [hm_getmark elems 2] 	puts '[hm_marklength elems 2] elems have normal ~ ($nx,$ny,$nz) within +/-$tolerance degrees' }
