Issues with Exporting Generated Solid Geometry from Hypermesh to CAD
I am new at using Hypermesh and I am trying to use it to convert enclosing surfaces that I created in AutoCAD to a solid via the Boundary Solid Option. I got to clean the geometry file and getting rid of free edges and generate the Solid in Hypermesh. However, when I try to export this solid geometry as a STEP file and open it in AutoCAD, the resulting exports turns out to be a single surface instead of a solid. Is there any way I can export this resulting geometry as a solid?
Hi Adriano,
Thanks for your comment. I tried exporting via Parasolid format but it did not work either. Once Hypermesh is done exporting the file, it displays "Entity Combined with Units outside Parasolid Modeller limits; check units and dimensions for good results". Please refer to the attached snapshot for my export parameters.
For context, I am trying to model an ancient historical structure, which explains the fact that the geometry has large dimensions. I need to export the solid geometry for visual comparison purposes and for later use of the solid to add/ edit features in AutoCAD.
Do you think there might be another way to achieve this? Thank you so much for your help!
have you tried exporting other open formats, such as parasolid?
