Hi all,
I would like to change the font size of main menu in HyperMesh.
Is that possible??
Press O on the keyboard to enter option panel or Select preference from Pulldown menu and select menu config.
See attached screenshot.
Regards
Rahul R
Thanks, but this chages just the bottom panel (panel m):
I'm looking for a way to change entire menu.
Hi all, I would like to change the font size of main menu in HyperMesh. Is that possible?? 1.png
Hi
right click on desktop and select 'personalize'
click on 'display' at left lower corner and select appropriated size
If you want to change font size partially, make a tcl script and configure font size for expected widgets
Hi right click on desktop and select 'personalize' click on 'display' at left lower corner and select appropriated size If you want to change font size partially, make a tcl script and configure font size for expected widgets
Hehe, I do right click .... everywhere but can't found 'personalize' on my HM13 /emoticons/default_sad.png' alt=':(' srcset='/emoticons/sad@2x.png 2x' width='20' height='20'>
I mean right click on window desktop instead of hypermesh
/emoticons/default_wink.png' alt=';)' srcset='/emoticons/wink@2x.png 2x' width='20' height='20'>
