Mode analysis for a 1d-beam-Model with HyperMesh
Altair Forum User
Altair Forum User
I have to do an mode analysis for a circular rotor with HM. Therefor I created two cross sections with Hyperbeam and chose them in the property cards. While creating the 1d-beam-elements I picked them of course. The material, BC, LoadCollector mode and load step are defined.
What else do I have to do for an successful mode analysis of a 1d-elements rotor?
Best regards
FloMa
  • Altair Forum User
    Altair Forum User
    edited November 2014
    Hi FloMa,
    Looks everything perfect, have you defined a EIGEN card for modal analysis?
    Please refer to the tutorial OS-1020: Normal Modes Analysis of a Splash Shield for more information on modal analysis using OptiStruct
  • Altair Forum User
    Altair Forum User
    Hello Pagadala,
    Thank you for your fast answer. I perused the tutorial and it was indeed helpful ;-)
    Nonetheless it dosn't work. For Card image I use PBEAML (PBEAM generates many Errors - 'Prop missing or incorrect for element)
    Now I get the following Error: '1479, incorectly formatted numeric data in field 9 (if it is a character field, it should start with a letter)
    Heres the line from the input data: ($HMBEAMSEC PBEAMLASSOC)
    PBEAML 1 1 +
    Best gegards
    FloMa
  • Altair Forum User
    Altair Forum User
    Hi FloMa
    Have you referred a HyperBeam section in PBEAML card?
    can you make sure that the HyperBeam section is created using standard OptiStruct section library and try again?
    <?xml version="1.0" encoding="UTF-8"?>post-7616-0-51928900-1416383720_thumb.jp
  • Altair Forum User
    Altair Forum User
    Good evening,
    Yes, I selected a BeamSection in the PropCard and it's a standard OS section.
    Any other ideas?
  • Altair Forum User
    Altair Forum User
    Is it possible for you to share the model?
  • Altair Forum User
    Altair Forum User
    Hi FloMa
    The element type CWELD is not compatible with PBEAM or PBEAML property. That is why you get the error.
  • Altair Forum User
    Altair Forum User
    Oh, I didn't even notice that option image/emoticons/default_biggrin.png' alt=':D' srcset='/emoticons/biggrin@2x.png 2x' width='20' height='20'>
    Now I selected for every PropsSetting PROD and it works ;-)
    Thank you for your support!
