hex mesh for irregular bones
I wonder if someone can help me understand how to mesh the attached object in hex only please.
I'm using hypermesh 13.0
Thank you
I think best way is to manually split the solid to regular shapes and mesh (or use solid map)
0 -
it's pretty complicated. Also in solidmap the one volume option does not work
0 -
It's not simple to make Hexa-only mesh. That needs alot of technique & time.
But I think GDTech's team could do that, of course, via a commercial contract :-)
0 -
I have managed these so far but struggling to get the whole thing to mesh. Any suggestions please?
0 -
Sometimes I get error message:
Non-mappable(1) along-faces form 0 loops. need 1.
Any idea what this means?
0 -
I think your splits are not mappable
my strategy is like this (sorry it's not completed
/emoticons/default_rolleyes.gif' title=':rolleyes:' />)
0 -
Thanks but I'm not sure what you did. Would you explain please?
0 -
Is it possible to create a mixture of penta and hex elements? How please?
0 -
From point of view of mapping method, if your starting 2D mesh is quad only you got hex only 3D mesh. If your starting is mixte mesh (quad+tria) you got mixte hexa-penta 3D mesh.
0 -
do you think I can you a morphing approach for this geometry to get hex mesh?
0 -
I have hypermesh 13. Any chance you can import it to this version please?
Thank you
0 -
Did you do just a normal shrinkwrap without specifying features or did you do a surface quad mesh first then shrink wrap?
0 -
For shrinkwrap there is no need of surface mesh.Just select component & set solid elements with lesser jacobian.I tried with 5 mm element size with .3 jacobian. So its a few click meshing process.
0 -
Is there a better way I can do this so that I can get good element quality because my model will involve other parts in contact.
0 -
try tetra mesh, then shiftF6 split it into hexas
0 -
It's quite a quick way but the jacobians for all elements become negative. Any ways to fix this please?
0 -
If you like 'Splitting' method, you have to accept some 'not-so-good' quality.
0 -
Hello Tinh,
I am running into an issue hex meshing a muscle STL. I was wondering how you drew the outlines that separated the solid object into multiple sub-components which could then be meshed. In the example you provided, only one of these components is hex meshed and this looks like the process I need to follow to fix my problem. I am new to HyperMesh, so any advise you could provide would be of great help.
Thank you,
Jack
0 -
Because you are new to hypermesh, i suggest you join altair training courses
I dont know how it can be done, 3d work is not easy, just try and error
