CBUSH SPRING
Hello everbody,
in the following picture you see 3 examples of a spring (CBUSH). The only difference is, that the node in the middle (were the force is) has different coordinates in each example.
I don´t understand why the Results are so different.
In example one (on top of the picture) the result is nearly 0
In example two ( in the middle of the picture) the node is -1 in y-coordinate and the difference is huge!! There the max displcement in Y is -3306
I have absolut no explanation for that.
Thanks for helping /emoticons/default_smile.png' srcset='/emoticons/smile@2x.png 2x' title=':)' width='20' />
We don't, either /emoticons/default_rolleyes.gif' title=':rolleyes:' />. Please send us your *.fem file
0 -
Here are the three examples, shown in the picture
0 -
Do you know what the problem could be?
0 -
I am sorry. I was busy. Tomorrow i will check.
Hoping someone will help you fix it soon
0 -
Hi @marvin1991 Did you provide any CID for CBUSH elements? If not can you keep it zero by card editing the elements and check if this helps.
0 -
But your result is not making sense or? You have the highest displacement at the constrainsts. But the force is in the middle, between the springs. And even inthe middle the displacment is 1,9*10^-9 in the girst example. Thats nearly 0 ..
0 -
Yes that is because of the I made the CBUSH rigid just to check if this is valid.
Without CID solver gave a random displacement and with CID set to zero it is giving expected results.
it is recommended that another CID be selected to define the element x-axis.
0 -
okay thanks.
But when i increase the force and lower the K1 factor the displacement is still nearly 0 ..but why?
Can you tell me how to define the elemet x-axis? I have never done that before. Maybe you can send me a little example?
Thanks for helping!! /emoticons/default_smile.png' srcset='/emoticons/smile@2x.png 2x' title=':)' width='20' />
0 -
Hi Marvin,
I did not notice the K1 factor and load change. I will check this.
You can create a local system and set the local system to elements.
0 -
This is with a local system and apply stiffness in right direction
0 -
Awesomme! That looks good /emoticons/default_smile.png' srcset='/emoticons/smile@2x.png 2x' title=':)' width='20' />
Is it possible to send me that model?
0 -
