Hybrid meshing Connectivity
Altair Forum User
Altair Forum User
Hi to all,
I am having a doubt in hybrid meshing. When hidden line option is used in hybrid meshing, I can see the face elements at the intermediate region (i.e, between tetra mesh and brick mesh).Normally it happens where connectivity is not proper. But I verified manually it shows good connectivity (I tried equivalance option also).
Is it acceptable? But it is not happening when I am using brick mesh alone.
Thanks.
  • Altair Forum User
    Altair Forum User
    edited October 2012
    Although you have a proper node-node connectivity, the faces-tool will still find a free face because from a geometrical point of view you have a quad face on one side and two tria faces on the other side.
    (On a side note: depending on solver, analysis type and element formulation you may observe in your results a continuous distribution of nodal results but a discobtinuous distribution of elemental results)
  • Altair Forum User
    Altair Forum User
    edited February 2014
    Tet elements to hex elements connectivity is a big questionable one.. Its is better to create penta elements as adjacent to the hex elements followed by the tet elements..
    To achive this, first create a solids, and then do a hex mesh.. after that the tet mesh the other solid which is attached to the hex meshed solid.. Hypermesh will automatically create a penta elements..image/emoticons/default_smile.png' alt=':)' srcset='/emoticons/smile@2x.png 2x' width='20' height='20'>
    image/emoticons/default_cool.png' alt='B)'>
  • Altair Forum User
    Altair Forum User
    edited March 2014
    For Tet-Hex connection, we use pyramid elements.
