Hi all,
How can I plot the eigenvectors of a mass-spring system?
I have a system like this: constraint ----spring-----mass-----spring-----mass-----spring-----constraint
A 2 degrees of freedom system, in a modal analysis will output 2 eigenvectors. I would like to see the vectors in the output file along with the eigenvalues (it is only for educational purposes). How can I do it?
