I am working on Multibody dynamics, i have a mechanism which has rotational as well as translational motion, Now i wanted to rotate it with respect to axis sobi selected cylindrical joint but i am not able to rotate it.
Hello dhaval,
please Check the below steps for cylindrical joint
Step : 1
Create point> Create Body> Create joints > Create Motion
Step : 2
In motion option select joint and go to property and give proper expression for motion
and try to run your model.
please explain what type of error is it showing? or Share your model.
Actually there is no Error, I wanted to rotate it but i can give only translational motion, and it is AOC 2017 Faculty model
OK, in this case you have to select different option
there are two options one is transnational motion and second is Rotational motion, so by default there will be transnational motion.
you have to manually change it to rotational motion and give appropriate expression for motion.
