is there a way to export the PolyNURBS mesh (e.g. as .stl-file) without the NURBS-Body generated inside?
Max
Hello Max,
you can try the following:
Hopefully it works,
Best regards,
Mario
It worked very well! Thanks a lot!
Solved, never mind.
