I have to model a dipole using cylinders (can't use segments since the dipole is very 'fat'), but I don't know how to create the excitation for such a dipole. Can someone help?
A dipole antenna made from a cylinder (and thus meshed into triangles) presents two common problems to users: Firstly how to excite the dipole and secondly how to create a mesh that follows the curvature of the dipole but which is not overly discretised. This how-to gives a step-by-step guide to creating this antenna.
An alternative to the edge port would be to insert a small separation between the dipole halves and create a short wire between the halves. Then a wire port can be used.
Since the geometry is curved, the mesh will have to represent the curvature. The advanced tab of the Create Mesh dialog can be used to adjust the curved geometry approximation settings. Alternatively, for MoM solutions users can enable Higher Order Basis Functions. CADFEKO will then mesh curved triangles.
