Ply Card Edit apply coordinate system
I am quite beginner in Hyperworks and I am currently modelling a laminate (HC panel) with different plies. Whenever I make a modification in the mesh, before running the calculation I need to re-open Ply card and specify elements that are included in each ply, because they are lost due to mesh (thus, element) modification.
I am wondering if there is another way to specify plies, because it might be relatively annoying to update this part of the model each time a mesh modification is carried out; in this case, number of plies is not extrenely big, but it can happen that a model consists of many of them, leading to a high waste of time. For example, that instead of selecting elements which would be involved in a ply, surfaces could be selected. Any help would be helpful.
Thanks in advance.
Regards
Hi Drew,
Try with lines instead of elements/element sets
0 -
Hi Prakash,
Thanks for your quick reply!!/emoticons/default_smile.png' srcset='/emoticons/smile@2x.png 2x' title=':)' width='20' />
