Pure Hex mesh
I am a student research assistant and am in a little bit of a fix.
I have a geometry as shown in green in the figure attached. As its a regular geometry getting a hex mesh is not a problem except for one complication that i require an extremely fine mesh in the region shown in in red and gradually increasing mesh size for the rest of the geometry. This is couple with a chamfer ot one of the edges.
Is it possible to get a purely hex mesh for this geometry and mesh requirement. If so how.
Yes, it's possible.
But 'pure hexa' with bad jacobian is not better than 'dominated hexa with some penta' by point of view of finites elements quality.
How to create below varying size hexa mesh strecture over pipe geometry
I am new to Hypermesh
It's so simple.
Build your surface mesh (on small diameter for example) with this varying density.
Then do mapping mesh to big diameter surface.
'Hexa only' maybe not possible with your model. But with some 'penta' I think that's possible.
Send me your geom, I'll try it
/emoticons/default_smile.png' alt=':)' srcset='/emoticons/smile@2x.png 2x' width='20' height='20'>
