How to change the color of the letters in the POST?
Do you mean changing color in Titles (POST page)
In Titles panel you can use text attributes to change the color of text.
Hi, Do you mean changing color in Titles (POST page) In Titles panel you can use text attributes to change the color of text.
I mean this.
There is no direct way to change the color, but you can change the amount of RED, GREEN and BLUEs you want in the contour.
Click on the contour for which you want to change the color and you should see something like below:
You will notice three cells. first is RED, second is GREEN and third is BLUE.
For all red color set enter 255 which will make the cell to red.
Thank you! I have solved my problem!
