Hello at all,
My Problem:
- have got two nodes (node 1 and node 2) --> node 1 is the reference for current position; node 2 is the reference for target position
- when using hm_getdistance nodes 1 2 0 ,
i get the following answer:
573.68267674323 495.66721 3.8981341703782e-014 288.8353
total distance x-distance y-distance z-distance
I´ll put the values for total distance and x-, y-, z-distances in a subsequent command for translate a hole component from node1 to node 2.
Therefore i need to create a vector with
*createvector 1 $x $y $z
*translatemark components 1 1 $total_distance 1
How can i get access or refer to the single values?
Thanks for your help
/emoticons/default_smile.png' srcset='/emoticons/smile@2x.png 2x' title=':)' width='20' />
My latest try:
*createmark components 1 'displayed' # *createmarkpanel nodes 1 'choose node 1' *createmark nodes 1 # *createmarkpanel nodes 2 'choose node 2' *createmark nodes 2 # set xVal [hm_getdistance nodes 1 2 dataname=x] set yVal [hm_getdistance nodes 1 2 dataname=y] set zVal [hm_getdistance nodes 1 2 dataname=z] set totVal [hm_getdistance nodes 1 2 dataname=tot] # *createvector 1 $xVal $yVal $zVal *translatemark components 1 1 $totVal
the problem is the 'dataname='
