How to stop tcl script after warning message?
User: "Altair Forum User"
Updated by Altair Forum User
Hi everybody,
how can I stop a tcl script, after a warning message?
I have the following expression:
if {$outerdiameter > $innerdiameter}  {
} else  {
   tk_messageBox -message 'WARNING - Please check your input! \n
  Outer diameter = $outerdiainput mm \n
  Inner diameter = $innerdiainput mm' -type ok
outer- and innerdiameter are variables I defined earlier in my script.
Now I would like to stop the tcl script from working on, if the message box appears.
Or even better would be if it is possible to add some command that after the message box appears tcl moves back to a specified line in the script. Something like go to line 5.
thanks in advance!
1 - 4 of 41
    User: "tinh"
    Altair Community Member
    Updated by tinh
    To stop script, use tcl command 'return'
    to jump back a specified line: there is no command to jump but you can do a loop and check condition to break the loop, example
    while {$outerdiameter > $innerdiameter} {
    set       outerdiameter [hm_getint outer]
    set       innerdiameter [hm_getint inner]
    OP
    Hi tinh,
    the return command works fine!
    I tried the 'while' command too but nothing happens  :unsure:/emoticons/default_unsure.png' title=':unsure:' />
    example:
    set outerdiameter [ hm_getstring 'Outer diameter in mm']            --> My input is 10
    set innerdiameter [ hm_getstring 'Inner diameter in mm']            --> My input is 10.5
    Now I thought it will bring me back to my input dialog, because innerdiameter is bigger than outerdiameter ??? Am I doing something wrong?
    Thnaks in advance
    User: "tinh"
    Updated by tinh
    Hi
    because 10>10.5 is FALL so body script of 'while' will not be evaluated
    you have to change 'while {$outerdiameter > $innerdiameter} {'
    to  'while {$outerdiameter < $innerdiameter} {'
    OP
    Hi
    Now it works perfectly!!!
    That's what I wanted to have in my tcl-file :D/emoticons/default_biggrin.png' srcset='/emoticons/biggrin@2x.png 2x' title=':D' width='20' />
    Thank you very much I really appreciate your support!
    Best regards,
    Tomi
