Problem with creating splits
Altair Forum User
Altair Forum User
Hi, i am a student participating in Formula SAE. I am trying to make a 2D mesh of our spaceframe in Hyperworks, I have encountered a problem.
I want to create a split at the intersection of these two surfaces
I have tried to split them using trim with surfaces.
However the surfaces won't split.
I have tried many things to overcome this, but I end up stuck with this problem. I would be grateful if anyone could help me with this issue.
Thanks !
  • Altair Forum User
    Altair Forum User
    edited December 2014
    If you have some problem with 'trim with surfs', maybe try 'trim with lines' ?
  • Altair Forum User
    Altair Forum User
    Thank you for for your reply. I tried doing that but I was unable to get the line to split the surface along the contour along which the two pipes intersect. I can't figure out what I have done wrong.
  • Altair Forum User
    Altair Forum User
    If you could share your model, I can have a look at
  • Altair Forum User
    Altair Forum User
    Thank you for your offer to help. I have sent a link to the file through a private message.
    Thank you so much!
  • Altair Forum User
    Altair Forum User
    @richard26: check your PM box.
  • Altair Forum User
    Altair Forum User
    Thank you !!!
  • Altair Forum User
    Altair Forum User
  • Altair Forum User
    Altair Forum User
    The same problem is reoccurring elsewhere in the model. Could you please explain how you did it ?
  • Altair Forum User
    Altair Forum User
    When you can't split surface by another surface, try split them by line. Where're the lines ? Just create them by 'intersection' between surfaces.
    After that, you need also merge edges.
  • Altair Forum User
    Altair Forum User
    I figured out how to do it.
    Thank you so much !   image/emoticons/default_smile.png' alt=':)' srcset='/emoticons/smile@2x.png 2x' width='20' height='20'>
