How to calculate the no of elements after the simulation on hyperview. I want to know in my simulation if any element has been deleted.
Hi Datta,
There are several ways to get number of elements. One way which I find it easy is,
1) Go to Mask panel in HyperVIew
2)Select all the elements>>All
3) At the bottom left you should see number of entities
You can also use the same procedure and get the number of elements with Query panel
