Altair RISE
Nominate Yourself Now!
Questions about connectors
User: "Altair Forum User"
Updated by Altair Forum User
I'm modeling a RC wing and i need to glue (Araldite epoxy) some parts. I'm using 1D -> area -> adhesive (Gap), which generates RBE3 elements (http://imgur.com/ds13Iva)
In some components I used seam -> adhesives (hexa) to glue edges.
There are better methods to glue components?
*update*
I forgot to say that the connectors aren't gluing the parts... Using Weld works fine! (I guess the problem is the perpendicular surfaces)
*update 2*
Thank you Tinh. The Hexa (adhesive) worked! The problem was the perpendicular faces, in this case the correct connector is Seam. I assigned the resin properties to hexa elements, as you mentioned.
Best regards,
Daniel Andrade
1 - 1 of 11
    User: "tinh"
    Altair Community Member
    Updated by tinh
    Hi, I think:
    if you use rbe3 only, you neglected properties of araldite epoxy
    if you use hexa, you can assign its properties to hexa elements
