Torsion constant formula use in Hypermesh
Altair Forum User
Altair Forum User
Hello everyone,
I am working on an FE model containing beams that have a square (or rectangular) cross-section. As a first example, I used a beam with a square cross-section. Each side measures 20e-2m. When I export my model in LS-DYNA format, I see that a *SECTION_BEAM keyword is created. I understand well the first parameters from secid to itt, but I can't understand how the j parameter is computed.
Using Hypermesh for a square cross-section with a 20e-2m side, I have J=2.25310E-4m^4. However, when I try to find this value again using formulas from the wikipedia page (https://en.wikipedia.org/wiki/Torsion_constant), I can't find the exact same value. Depending on the used formula, I either find J = 2.25000E-4 m^4, J = 2.25600E-4 m^4 or J = 2.25333E-4 m^4. These values are close (especially the last one), but still they're not equal to the one given by Hypermesh. Right now, it might not be seen as a problem, but what if the values become too different if I use other cross-section values? That's why I need to understand what Hypermesh does.
I have searched the Hypermesh documentation but I didn't find any information about how this value is computed. And I need it to understand this because I want to run comparisons between commercial solvers and personal codes.
Does anyone have a hint about how to find this value? Thank you in advance,
Corentin.
  • Q.Nguyen-Dai
    Q.Nguyen-Dai Altair Community Member
    edited February 2018
    Here's a square 0.2x0.2:
    <?xml version="1.0" encoding="UTF-8"?>HyperMesh_0_2x0.2_section.thumb.png.d847069005dd119fc4262b486b415f2a.png
    Data:
  • Altair Forum User
    Altair Forum User
    Thank you, that's exactly what I was talking about :)/emoticons/default_smile.png' srcset='/emoticons/smile@2x.png 2x' title=':)' width='20' /> But here I can only see the final value, and not how it was computed, which was my question.
  • Sanjay Nainani_20973
    Sanjay Nainani_20973 New Altair Community Member
    You can go to help section where you can find the reference book from which the hyperbeam data is taken.
    Please see the below picture.
    <?xml version="1.0" encoding="UTF-8"?>image.thumb.png.1db09e91265b4fb5e6133f264e96ba50.png
    Thankyou
  • Q.Nguyen-Dai
    From here : https://en.wikipedia.org/wiki/Torsion_constant
    For square section, you have:    J = 2.25 a^4 with a = 0.2/2 = 0.1m
    So: J = 2.25 E-4 m^4 ===> same value computed within Hypermesh.
  • Altair Forum User
    Altair Forum User
    @Sanjay Nainani thank you, I think I missed this page because that was what I was looking for :)/emoticons/default_smile.png' srcset='/emoticons/smile@2x.png 2x' title=':)' width='20' />
    @Q.Nguyen-Dai thank you, I knew this page but these formulas are approximations from what I understand and I was looking for the exact formula :)/emoticons/default_smile.png' srcset='/emoticons/smile@2x.png 2x' title=':)' width='20' />
