Hi guys i performed a modal analysis in hypermesh but i'm not able to extract a table with all natural frequency and mode shape that i found. Is there any command that i need to apply in my imput file ? i uploaded my BFD file
Hi francesco aloschi
You can try this:
Go to query panel in Hyperview (marked green), select the component and required outputs you need from the list (marked red)
Then select the simulation step (marked blue) as Mode 1 and click apply. This will give you the outputs in the query window for mode1.
Similarly change the simulation steps to successive modes and get the outputs in query window.
Once you are done with the required no: of modes, you can click export (marked black) to output the results in query window into an excel format.
Hope it is clear.
Thanks
it works nut i need to have an excell file with all load case that i'm able to manage
