Error
during a simulation with MotionSolve, I get the following error. Althought it is described, I don't understand how to fix it.
WARNING: Stepsize has diminished consistently below h_min [=1.000E-06].
ERROR: At time=1.186E+00 the integrator failed to proceed.
----------- Possible Causes -----------------------------------------------------
(1) The integration has become unstable. Tighten (decrease) integr_tol, h_max,
or both in Param_Transient can help stabilize the integration. If the simulation
contains distinctive phases, use multiple Simulate, each with its
own proper integrator parameter setting, to selectively tighten the tolerance
during the period where instability is encountered.
(2) If the simulation was terminated because stepsize has diminished consistently
below h_min, reduce h_min in Param_Transient to force integration to continue.
(3) Non-physical inertia properties, such as mass=100 Kg and Ixx=Iyy=Izz=1 Kg*mm^2,
or extremely small inertia on a part with an unconstrained degree of freedom.
Make sure the modeling data, in particular the part inertia and the gravity, are
specified in proper units consistent with the units given in Param_Unit element.
(4) Beam, flexible body goes out of linear range, bushing has large rotation along
more than one axis, curve goes out of its interpolation range, higher-pair joint
goes out of the range of U or V, etc. Make sure fundamental modeling assumptions,
such as rigid contact assumption used in Force_Contact, are not violated.
(5) Motion displacement defined using LINSPL, AKISPL in dynamic analysis, or as a
function of model states (DX, VX etc), as well as forces defined as a function of
other forces, can cause hard convergence and integrator failure. Avoid these
modeling practices wherever possible.
Can you please share the .log file with me?
