Hi ,
I need to give optional thickness value in property of a component in hypermesh.
Ansa Having this option like OPTT value but i dont know how to assign optional thickness value in Hypermesh
Thanks & Regards
Suresh Kumar V
Can you please tell me what kind of analysis you are doing and which solver are you using?
Thank you
Hi , I need to give optional thickness value in property of a component in hypermesh. Ansa Having this option like OPTT value but i dont know how to assign optional thickness value in Hypermesh Thanks & Regards Suresh Kumar V
What do you mean 'optional thickness' ???
I'm assuming you want to define the optional contact thickness in LS-Dyna, which is found on the *PART_CONTACT card. If so, try this:
1. click on the component in the Entity Browser
2. in the Entity Editor (located below the browser) click next to 'Options' to get a list of options for the *PART card. Select 'Contact'
3. OPTT should now show as one of the options.
Thanks Kevin
