Trimming Process simulation in Die Casting
MilanRaval
MilanRaval
Altair Employee
edited August 2024 in Altair HyperWorks
Trimming Process In Die Casting
The trimming process in die casting is a critical step that follows the casting of parts. It involves the removal of excess material, such as flash and runners, from the casting to achieve the final desired shape and dimensions. Here’s an overview of the trimming process in die casting:
Definition of Trimming:
Trimming in die casting refers to the removal of unwanted excess material from the casting. This excess material can include:
  • Flash: Thin projections of metal that form at the parting line of the die due to metal squeezing out during the casting process.
  • Runners and Gates: Channels through which molten metal flows into the cavity during casting. These need to be removed to separate the actual part from the sprue (runner system).
Dimensional Accuracy and Part Quality:
Trimming ensures that the cast parts achieve the exact dimensions and geometries specified in the design. During the casting process, features like flash and runners are formed, which must be removed to meet dimensional tolerances. Proper trimming controls the final dimensions of the part, ensuring it fits precisely into assemblies or meets functional requirements. The trimming process can affect the surface finish of die-cast parts. When done correctly, trimming removes rough edges, flashes, and any imperfections left from the casting process, resulting in a smoother and more aesthetically pleasing surface. This is crucial for parts where appearance matters, such as consumer products or automotive components. Improper trimming can potentially affect the mechanical properties of die-cast parts. Over-trimming or removing too much material can weaken the structure or compromise the integrity of critical features. Conversely, insufficient trimming can leave residual flash or uneven surfaces that may lead to stress concentrations or premature failure under load.
Trimming Process in Inspire Cast
Due to the trimming process, part quality can be compromised. Checking stresses and part distortion through simulation is a great way to identify the effects of the Trimming process.
The trimming process can be activated from the run submission dialogue box. Running with a trimming process setup, Inspire Cast will generate additional result types of trimming process in which user can visualize results like Displacement, Stress, and Von Misses,
image  imageimage
Benefits of Simulation for Trimming in Die Casting:
  • Cost and Time Savings: Reduces the need for physical trials and prototypes, saving time and costs associated with tooling adjustments and material waste.
  • Process Optimization: Enables fine-tuning of trimming parameters to achieve optimal part quality and dimensional accuracy.
  • Risk Reduction: Identifies potential issues such as tool wear, deformation, or stress concentrations before production, minimizing risks of defects or failures.
In conclusion, simulating the trimming process for die casting through Inspire Cast is a powerful technique to optimize production processes, improve part quality, and ensure efficient manufacturing of complex components.
