Installing Inspire 2024 on a machine without Internet access
Matthieu Pupat
Matthieu Pupat
Altair Employee
edited August 2024 in Altair HyperWorks
To install Inspire and manufacturing applications on a machine with no internet access, you will first need to download packages from a machine connected to the Internet, then transfer packages on the target machine and install there. Detailed steps are provided below:
  1. On a machine connected to the Internet, download the 2024 installer from Altair Marketplace.
  2. Start the installation process which will download the contents inside the folder 'AltairXpress2024'.
  3. Once the download is complete, the actual Inspire installation will start. Hit Cancel.
  4. Move the folder 'AltairXpress2024' to the machine with no internet access.
  5. Double click on the AltairInspire2024_win64.exe inside the folder to start installation. For manufacturing products the installer to start will contain the manufacturing product name. E.g. to install Altair Inspire Extrude, start AltairInspireExtrude2024_win64.exe.
