How to submit Radioss job by using Standard Application Definition
Srikar Gupta Golla Venkata Peetambara
Srikar Gupta Golla Venkata Peetambara New Altair Community Member
edited July 2024 in Altair HPCWorks
  • Step-1:Login to Access Job submission web portal and Select Radioss Application Icon.
  • Following image showing the same:
  • A screenshot of a computerDescription automatically generated
  • Following image showing the form loaded after selecting Application definition:
  • Step -2:Drag and drop input file at Input files (starter file / engine file / both) (.rad or .zip) form field.
Field Name
Version
Radioss application Version to run the job.
Job Name
Job Name / Default is starter filename excluding extension
Radioss run type
Select the type of Radioss run (starter / engine / both)
Select Parallelism
Explained below
What is input form field “Select Parallelism Type”?
  • SERIAL – To run the job using single CPU core. Ideal for one node one core job.
  • SMP – To run the job using more than one CPU core and less than or equal to the CPU cores in one compute node. Ideal for SMP supported application to run in single node.
  • MPI – To run job using CPU cores for more than one node using MPI communication. Ideal while running multi node job.
  • Hybrid – To run job using the combination of SMP and MPI mode.
    Total cores = (number of MPI will be equal to the number of nodes) * (number of cores (usually all cores) from each node)
  • Drag and Drop input files (starter / engine both) to run the job/workload,
Field Name
Number of Cores
Select Total number of cores required for job.
Total Memory Required (in core) for Simulation (GB)
Total amount of memory required for the job.
Total Out of Core Memory Required (in GB)
Total scratch disk space required for the job.
Starter file
Starter file for the job(The starter can be in the form of 0000.rad or in the .zip where the .zip should contain 0000.rad)
Engine file
Engine file for the job(The engine file can be in the form of 0001.rad or the .zip which contains 0001.rad after unzipping
Run Type
Performance - If all number of cores in node is not allocated for this job, Remaining cores will not be allocated for other jobs.
Throughput – If all number of cores in node is not allocated for this job, Remaining cores will be allocated for other jobs.
Output Directory
Directory name to copy back all job files. Default as per site specific configuration
  • Step -3:Click on submit button to submit the job.
Following are the  form fields can be modified as per job requirements.
  • Following are the default visible Input form fields:
Field Name
Default
Version
Select the version of the application to use.
Configurable / Usually latest version
Job Name
Name of the job
Note: Special characters and spaces are not allowed in job name.
Starter file name without extension
Radioss run type
Select the behaviour of the solver
both: Run Radioss starter and engine
Starter: Run just Radioss starter
Engine: Run Radioss engine.
Default: both
Select the parallelism Type:
1. SERIAL: Allows the job to be run with single core/CPU.
2. SMP: Allows the job to be run with CPUs available within one node in a cluster. Uses Threads.
3. MPI: Allows the job to be run with CPUs available across multiple nodes. Uses MPI Processes.
4. HYBRID: Allows the job to use a combination of MPI processes and threads. Generally faster and uses an optimal memory foot print.
SERIAL
Number of Cores
Select the total number of CPUs/cores to be used.
1
Select the total memory required for the simulation in GB. This information is generally available in the simulation output files. Selecting a value closer to the real memory need will increase the chance of the simulation to complete successfully.
Note: This is NOT the same as memory per core.
User editable with reasonable default value based on the selected number of cores.
Select the total out core memory required (local scratch disk space) for the simulation in GB. This information is generally available in the simulation output files. Selecting a value closer to the real out core memory need will increase the chance of the simulation to complete successfully.
Starter file (.rad or .zip)
Select the starter file to be used with the simulation which can be in the form of 0000.rad or .zip(which contains the 0000.rad file)
Note: Special characters and spaces are not allowed in file name.
Engine file(.rad or .zip)
Select the engine file to be used with the simulation which can be in the form of 0001.rad or .zip(which contains the 0001.rad file)
Run Type
Selecting Performance mode will ensure that your job runs on an exclusive set of nodes and should expect your jobs to finish faster. On a busy cluster, this may lead to higher wait times.
Selecting Throughput mode will cause the scheduler to find the required resources even if they are scattered across several nodes in the cluster. This may increase the possibility of your job starting sooner than in the Performance mode. Your simulations may run longer than usual.
Default: Performance
Output directory
Specify the directory where the result files will be stored after the job is complete.
User editable reasonable default : /stage/username/jobname_timestamp
  • Following image showing when we are Enabling show all option:
Apart from default Additional form fields are visible here, Following are the additional form fields other than default form fields:
Field Name
Default
Queue
Select the queue to which the job must be submitted.
Number of threads per MPI
Will use the thread count selected per MPI process; A total of " + <above selected cores> + " CPU cores selected will not be exceeded. Use more threads to minimize Memory footprint.
User editable reasonable default : 1
Generate H3D
Check this box if you want to generate a compressed binary file, containing both model and result data.
User selectable reasonable default: True
Compress H3D
Check this box if you want to generate a compressed file of your generated H3D file which contains both model and result data compressed.
User selectable reasonable default: False
DELETE ANIMATION FILES?
Check this box if you want to delete animation files you have generated these animation files are deleted once your h3d file is created.
Run In Place
Check this box if you want to run your job in the same directory where your input file is. This will prevent the expensive file copies. May impact performance of the simulation.
Include Files
Select the include files to be used with the simulation. Generally, the include files are auto added. But this is only an assist feature. Please ensure all the necessary include files are added and available before submitting the job.
Schedule After
Select this option to schedule your job to run at specific time in future. Note that the job becomes eligible to run after the selected time. Actual start times may differ based on the resources available on the cluster.
Kill Job After
Specify the estimated time that your job is expected to run on the cluster. Providing a good estimate increases the chances of your job starting sooner.
Note: The scheduler will kill the job if the actual wall time exceeds the estimated time specified.
Dependency type
Specify the Dependency Type:
afterok: start the current job only if the specified depend job is successful.
aferany: start the current job after the specified depend job irrespective of exit status.
Default: afterok
Dependent on Job
Specify the job id of a previously submitted job after which the current submission is expected to run.
Additional Options
Specify any valid command line options that you need to pass to the application. The options will be passed verbatim to the application.
