Altair Monarch Exercise 26 - MEDITECH Detail Trial Balance vs AP Transactions
Baba_Majekodunmi_703
Altair Employee
edited October 2024 in Altair RapidMiner
Exercise Info
  • Application (Classic vs Data Prep Studio): Classic & Data Prep Studio
  • Level of Difficulty (Beginner, Intermediate, Advanced): Beginner
  • Skills/Features Tested: Detail, Append, & Group Footer Templates, Join (Lookup Join)
  • Systems of Record: MEDITECH Expanse
  • Estimated Time to Solve: 15 mins
  • Exercise files required are attached in the Zip File Below;
    • Meditech Expanse Detail Trial Balance Sample.txt
    • Meditech AP Transactions for SQL.csv
Exercise Overview
You are an Accountant at a Critical Access Hospital and the Controller has asked you to compare Accounts Payable activity between the GL and the Data Repository to identify and differences between them.
Classic
Create a Monarch Classic Model to Capture just the Vendor Debits and Credits activity within the Meditech Expanse Detail Trial Balance Sample.txt Report to answer these questions;
  1. Create a calculated field for Net Amount (Debit - Credit), What is the total Net Amount?
  2. Create a summary to identify the Top 1 Vendor had the largest Debit Amount. Who is that vendor?
Data Prep Studio
Create a Monarch Data Prep Studio Workspace that Joins (Lookup Join) the Meditech Expanse Detail Trial Balance Sample.txt to the Meditech AP Transactions for SQL.csv, to answer the following question;
  1. Which Vendors are on the Detail Trial Balance, that are not in the AP Transactions SQL table?
Exercise Answer
Not sure you got the correct answer? No problem. Watch the video below for a demonstration of this exercise from start to finish.
