Data Analytics - Ask The Expert Recurring Series Monarch & Monarch Server(Automator) focus. May 23, 2023 Session reviewed What's NEW in version 2023 before going into LIVE Q/A.
Roberto Del Rio Salgado
Altair Employee
edited October 2024 in Altair RapidMiner
Ask The Expert Series on May 23, 2023
The Session began with a brief overview of What is NEW in Monarch Complete Client version 2023 and Monarch Server version 2023 before diving into the LIVE Questions.
The Session began with our Expert reviewing the following:
  • The session began by Mo reviewing what is NEW in Monarch v.2023
    • Reviewed updates for Monarch Client
      • Listing of new items.
    • Reviewed updates for Monarch Server
      • Reviewed how to use the Monarch Server Database Inspector with an example file that can run to see if the Server processes might have any deprecated connections.
  • Mo shared new use case of Monarch Server in obtaining emails that send over PDF Invoices.
LIVE Questions Submitted:
  1. Do you have a sample process that demonstrates Active Directory functions, which I could utilize for showcasing purposes to my IT group?
    • Mo provided an overview of the Active Directory configuration but couldn't present the entire workflow. Rebecca suggested scheduling time with their Account Manager to ensure a comprehensive demonstration of the functionality.
  1. Is there a method to implement Report Verify within an Automator process, as a means to safeguard against and detect alterations in inputs to production processes?
    • Mo demonstrated how to set exception within Verify Workspace.
PART II Question:   I was thinking about how I could find out that a value is longer than the field length, a scenario where the Report Verify feature would alert me.
    • With Verify Model one can then check the text length, however Workspace is not able to do it.  Within Workspace one can only check the table/results or rows.
Additional Resources:
Monarch Learning Guide   Monarch v.2023 Release Notes   Monarch v.2023 Quick Start   Monarch v.2023 Release History
