Modelization of a Remote Control for Miniature Circut Breaker using Activate/MotionSolve Co-simulation and Flux3D
Victoria Velavicius
Victoria Velavicius
Altair Employee
edited April 2023 in Altair HyperWorks
Presentation by Remy Orban, Senior Mecatronic Designer at Schneider Electric.
A business opportunity required the adaptation of a Miniature Circuit Breaker remote control for a specific application. To comply with time to market requirement, multiphysics model was the best way to run a feasibility analysis but the mechanical sub-system complexity makes this case difficult for conventional 1D modelling. As a result, co-simulation was used to build a comprehensive model in Activate using both, electromagnetic data from Flux3D and rigid body dynamics from MotionSolve.
