Hi Ram,
Please go through these case studies: http://www.altairatc.com/india/bangalore/technical-presentations.htm
Dear George,
I had tried to solve my problem using Geometric non-linear Implicit Dynamics analysis .
Total run time is for 21 seconds but it is solving for 15 seconds then shows the below error.
Following error occurs after some iterations.
MESSAGE ID : 79
** ERROR : RADIOSS IMPLICIT STOPPED DUE TO TIMESTEP LIMIT **
ISTOP=-2
Please provide your guidelines.
Thanks
RAM
Hi Ram,
When the time step is smaller than the input minimum one (please check /IMPL/DT/STOP), RADIOSS will stop the run with this message.
The reason is generally due to the convergence issue (DT_min). There is no general workaround for convergence issue, as outlined below:
1.Check the model, constraint conditions, materials, contact interface defines and so on.
2.Switching other convergence criteria (see Itol in /IMPL/NONLIN).
3.Try /IMPL/NONL/SMDISP to see if the issue came from geometric nonlinear
Dear George,
After reducing the minimum timestep DT in TSTEPNL ,
i didn't get this error.
MESSAGE ID : 79
ISTOP=-2
But it shows this error
Thanks
RAM
Below are the suggested workarounds for error ISTOP=-4:
1.Check which solve method is used in /IMPL/SOLVER. Use another solve method.
2.Another frequent case is when the model is relatively large and the available free disk is not large enough. If the issue came from memory management, you could also force RADIOSS to use out-of-core resolution (/IMPL/SBCS/OUTCORE).
Please try with these options.
Hi Ram,
I presume that you are working on OptiStruct Profile.
Create a load collector with SOLVTYP as card image and Create/Edit it. You will get the options to change the solver type. Try with AUTO which automatically selects between BCS and PCG type.
Finally, edit the load step and recall the SOLVTYP you have created.
Dear George,
Yes ,i am using Optistruct and created the load collector with SOLVTYP card as you mentioned.
I am choose analysis type as Geometric Nonlinear Implicit dynamic analysis in Solver Definition in load step
In SUBCASE option ,the SOLVTYP is not available and unable to recall it.
please give your valuable suggestions
Thanks
RAM
OS-1500: Nonlinear Implicit Analysis of Bending of a Plate
