🎉Community Raffle - Win $25
Join and Win
Clear highlighted surfaces
I am selecting 3 nodes somewhere in my model in order to define a plane using the
*createmarkpanel nodes 1 'Select 3 nodes!'
command. In the process of the selection I am using the plane/line/edge highlight feature provided by HyperMesh(I keep pressing the LMB until it turns to a rectangle and then select a geometric feature). The problem is that the highlighted surfaces stay highlighted even after I've pressed the 'proceed' button.
Is there any way to undo the selection?
Regards, Stefan
1 - 4 of 41
    Thanks for the info.
    There might be a better way which I am not aware of, but you could simple do a 'dummy selection' afterwards, e.g.
    *createmark lines 1 displayed
    *clearmark lines 1
    Regards
    *clearmark lines 1
    Regards
    Thank you, but unfortunately it's not working. The surfs aren't temporarly highlighted anymore but as soon as you enter a panel and go back the surfaces are plain white again.
    I more or less accidentally worked around the problem by calling a commandfile in my TCL script. *trim_by_offset_edges did not work when I called it in my script (it worked if i executed the command in the command window) but it did, executing a cmd file. After that command all highlighted surfaces are not highlighted anymore :-)
    how about ...
    hm_createmark lines 1 'advanced' 'displayed';
    set lineList [hm_getmark lines 1];
    puts $lineList;
    *clearmark lines 1;
    this code will select the displayed lines and store the id in a tcl list.
    *clearmark lines 1
    Regards
